alright everyone, picture-heavy post.
I had just recently changed the fire ring on the gtx2867r, I didnt even put 100 miles so taking the turbo and lines off was not an option.
I decided to change the elbow while the turbo is in the car.
I ran a power line to my amp which was making contact with the wastegate, glad I found it before it would have damaged more or worse. You can see the black residue on the wastegate.
right click on image and open in new window for higher resolution.
As you can see I had a nice thermal zero blanket for the ATP elbow, I wont be able to use it
not that it wont fit, its the issue with access from top and coolant lines etc.
You can access the V-Band clamp from top. As you can see there is a significant differnce in weight! Hopefully I put it back together today and get some logs to Alan.
