I did, check out my build log. Link is in my signatureMind doing a writeup?
Sent from another garage.
I was originally going to do that! But the 12v outlet is moulded into the shifter surround and I didn't want to modify it since its a much more expensive piece to replace if I screw it up. Red button is going on soon too btwHeh, not bad!
PERSONALLY, if I was going to move the button from the stock position. I would much rather have it in the hole for the 12V right beside the shifter. With the Red Ford Power start button :big smile:
But I think it's fine where it is stock.
+1 for creativity tho
I was originally going to do that! But the 12v outlet is moulded into the shifter surround and I didn't want to modify it since its a much more expensive piece to replace if I screw it up. Red button is going on soon too btw![]()
Thats a great place to relocate your cigarette lighter to....View attachment 285370 I had no problem moving my start button to the power point location, however now I need to find a way to fix the hole in the dash. But I like the start button next to the shifter. The power point pulls out of the trim piece and I had to enlarge the hole slightly to fit the start button, I think it came out quite well.
this is exactly what I have been contemplating doing, my thought was to move the start/stop button down there and move the power port (or more likely just a fast charging USB port) up to where the start/stop button is.View attachment 285370 I had no problem moving my start button to the power point location, however now I need to find a way to fix the hole in the dash. But I like the start button next to the shifter. The power point pulls out of the trim piece and I had to enlarge the hole slightly to fit the start button, I think it came out quite well.
The red is a custom cap I made for the button so it still illuminates like the factory buttonwhat are you using for the red start button?
is it just the button cap for the GT350? i though the mustang ones were different since they have an LED light that sticks through it.
