1 - 9 of 9 Posts
Those look buttery smooth
Now, the front ST is part of the grill correct? So we can only change out the back one? I'd want both looking the same.
The front is held onto the bumper by adhesive, it can be removed just like the back one
Reactions: LockeLamora33
Thanks, I hadn't messed with it yet but thought I saw a comment in another thread saying you can't take it off. Good to know I can!!
Definitely can't go wrong with these emblems. I had the prior batch of them and they've stood up to the elements perfectly and add a really nice touch to the car
I could be wrong, but if those are ABS, which is a very common print material, then he probably did an acetone vapor bath the give the smooth glossy surface.
The vapor bath slightly melts the surface of the material and smooths out the surface
1 - 9 of 9 Posts
