1 - 4 of 4 Posts
I am looking to buy one of the CP-E Exhale kits with Tial bov, but noticed reading through everything it was also recommended to purchase the stage 2 motor mount as well. Is this more for the early 2013 STs that had the really crappy motor mount or does this count for the later STs that havethe eFocus(?) mount?
Just curious if it's honestly really needed at all because it's not money I was planning on spending and I have not seen that kind of recommendation for other charge pipes. I know the motor moves around a little bit but want to know if it'll be a real problem if I don't get the motor mount.
Thanks
It is recommended because there is movement with the oem motor mount and the tolerances are fairly tight, so we could fit that diameter pipe through there. people are running an oem motor mount with our exhale kit without issue, but we recommend an upgraded rear motor mount just in case.
1 - 4 of 4 Posts
