161 - 171 of 171 Posts
as much i as i want it the stock valve sucks. running higher than stock boost is prob not the best idea for this plastic bpv. i am going with the turbosmart plumback. no pshhht noise and can handle increased boost. this plastic one freaks me out.
Where did you find the plum back? I couldn't find it
thank you Breedt, I put it on and it's exactly what I want. With my resonator delete the car sounds perfectly to me....now I will wait the RS
Discussion Starter #168
If the BOV is plumbed directly to the intake manifold what ever boost you make will keep the valve closed. Using the factory BOV solenoid is a different story because it work in conjunction with the waste gate actuator solenoid and uses pure vacuum from the engine driven pump.
