1 - 3 of 3 Posts
Can you confirm whether or not your shift knobs are compatible with the FRPP Short Shifter, specifically regarding the reverse lock out?
Hey sorry I just saw this thread now. (I normally go directly to the big thread)
So the FRPP shifter should work the same as the stock shifter so the knobs should fit. If it does not fit, I can easily configure the knob to work. Typically it just needs a different height-adjustment screw to fit at the proper height.
1 - 3 of 3 Posts
