1 - 2 of 2 Posts
so Ive done a little research into the different stages and requirements, while using the COBB access port
stages 2 and 3 say it requires a cobb front mount intercooler or equivalent, but when i input all of the parts Ive installed on my car it says i can go stage 3...
there is an area where it has check boxes for all of your current upgrades and then will determin what stage you can run and it says stage 3...
can somebody please help here so i dont blow my engine to pieces.
373768
aftermarket parts are as follows - 2017 Focus ST
Injen Tuned Air intake
Steeda throttle body spacer
Steeda lowering spring
Megan racing CATLESS downpipe
full catback rousch exhaust
Cobb Accessprot
TurboSmart blowoff valve
Cobb Accessprot
Run a stage one map until you get an aftermarket fmic, then with the fmic you are stage 3
Reactions: OregunST
1 - 2 of 2 Posts
