1 - 20 of 45 Posts
THMOTORSPORTS COBB TUNING SPECIAL!!
What's up guys,
Here are some COBB Tuning products we have available and ready to ship for your ST's!
***IN STOCK
***READY TO SHIP
***GUARANTEED LOW LOW PRICES
We STILL have Accessport V2's in stock at a SEVERELY Discounted Price
COBB Tuning CatBack Exhaust
Part#591100​
Details:
The COBB 3” Stainless Steel Dual Tip Cat-Back for the Ford Focus ST is a direct replacement cat-back exhaust that boasts full 304 stainless steel construction, custom inline mufflers, and dual 4" double wall tips.
Part of the COBB Stage 3 Package, our 3” Stainless Steel Dual Tip Cat-Back for the Ford Focus ST is a direct replacement cat-back exhaust that boasts full 304 stainless steel construction, custom inline mufflers, and dual 4" double wall tips, resulting in a drone-free, unique exhaust note. Perfectly tuned out of the box with the Accessport and ready-to-run with easy installation!
Part of the COBB Focus ST Stage 3 Package
Ready to run with COBB OTS Maps
3" 304 Stainless Steel
Dual 4" Slash Cut Tips
Custom Inline Mufflers
CNC Mandrel Bent Tubing
TIG Welded
COBB Tuning Accessport V3
Part#AP3-FOR-001
Details:
The Accessport V3 is the world's best selling, most flexible ECU upgrade solution for Ford. Unlock power hidden within the vehicle by replacing conservative factory settings with more aggressive calibrations. Upgrade forever with off-the-shelf (OTS) calibrations for most bolt-on modifications. It's the last engine management solution you'll ever need.
Features:
  • Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
  • Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
  • Performance Measuring: Welcome to your own performance evaluation suite! Measure 0-60 mph time, 60 foot and ¼ mile ET’s. and Trap Speed.
  • Gauges – Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
  • Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 10 hours.
  • Shift Light: Set custom RPM warning lights for perfect shifts every time.
In depth COBB V3 walk through VIDEO
COBB Tuning Downpipe
Part# 591202​
Details:
Free up your Focus ST's engine with the COBB 3" Downpipe! This direct replacement for the factory downpipe features a 200 cell count high flow catalytic converter and 304 stainless steel tubing. The CNC machined v-band flange and 4" flex section ensures perfect OEM-like fitment. All of these features combine to provide a free flowing exhaust outlet for high energy exhaust gases to reduce turbo back pressure and increase turbo efficiency. This downpipe is the perfect step towards Stage 3 power!
Features:
  • 3" 304 Stainless Steel Construction
  • 4" Flex Section
  • 200 Cell Count Magnaflow Catalytic Converter
  • CNC'ed V-Band Flange
  • 2-Bolt Flange
  • 2.5" & 3" Gaskets are included to work with stock or aftermarket cat-ba
cks
COBB Tuning SF Intake System
Part#791100​
Details:
The COBB Intake for the Focus ST takes a great airbox design and makes it even better! We improved upon the factory airbox ram air ducting by including an oiled dual cone filter to increase airflow and to hear that great turbo sound. The constrained piping to the turbo is replaced with 3" mandrel bent aluminum tubing to maximize air flow while custom silicone couplers ensure a perfect OEM-like fitment. You can also proudly display your fine taste in performance modifications with your choice of body-colored COBB graphics for the intake tubing. The COBB Intake is the perfect first step towards Stage 2 power levels when paired with the COBB FMIC!
Features:
  • 3" Mandrel Bent Aluminum Tube
  • Powdercoated Wrinkle Black
  • Dual Cone Air Filter
  • 4-ply Black Silicone Couplers
  • Vehicle Color Coded Sticker
  • Maintains the Factory Ventilation Hose from the Valve Cover
For best pricing shoot me a PM!!!
1 - 20 of 45 Posts
