1 - 8 of 8 Posts
Just curious as to exactly how this works. I have it enabled on my AP, and I just need to know when exactly it is activated while driving?
Stage 3 93 octane OTS COBB tune:
Is it activated after ignition?
Is it activated only in sport mode?
Is it activated only in ESC OFF mode?
Or some other parameter?
Thanks.
all the time if you have it enabled regardless of anything else.
Yup it's all time. Although if you aren't in sport or esc off you won't notice it since the oem tc will kick in before the cobb version. I keep mine in sport mode daily
Do you have to program it yourself, or did COBB already put in the correct parameters? I haven’t updated my AP aim FOREVER
yup, I had stratified set mine to full time. Rather have it on more often than I want it off, so better default choice. Can still go in and turn it off.
So the answer seems to be: it’s ON full time but only actually useful when you’re in Sport Mode because that disables the factory traction control.
1 - 8 of 8 Posts
