Hopefully Cobb can chime in if this is a software update issue that needs to be patched...
So, I know that Catalyst Temp is a calculated figure; but upon arriving at work today, I noticed that my AP3 said that the max Cat temp was 2,862,686*F. Platinum melts at 3,500*F...
I may be wrong (sarcasm), but I highly doubt my cat reached temperatures ~290 times hotter than the surface of the sun...
Sounds like you are running your motor with that 200 octane racing gas waaaayyy too lean there!
:saint:
But seriously, I've never seen this. The times I have monitored catalyst and exhaust flange temps they have always been as expected in absolute values as well as behavior, with cat temp lagging and then overshooting increases in flange temp (as it should be).
I'd contact Cobb, but doing a firmware update and a reflash may also be a good thing to do (if you don't mind your OAR resetting).
So, turns out they released a firmware update specifically addressing this issue. My cat is not exceeding 2 million degrees.
Related Threads
Ford Focus ST Forum
1.5M posts
69.6K members
Since 2012
