Is it ok to use stage 1 map if all parts are not cobb?That would be Cobbs "Stage 1" map
Brand of the parts doesn't matter. It'll work the way it should as long as you have the correct part in general.Is it ok to use stage 1 map if all parts are not cobb?
Ok and with what I have installed all I need is a fmic to go stage 2? Waiting for the depo to become availableBrand of the parts doesn't matter. It'll work the way it should as long as you have the correct part in general.
Stage 1 is considered a car with an intake installed.
CorrectOk and with what I have installed all I need is a fmic to go stage 2? Waiting for the depo to become available
https://cobbtuning.atlassian.net/wiki/display/PRS/Ford+Focus+ST+Map+Notes
Map Notes
Stage1 Maps
Intake Requirements: Stock airbox with stock/COBB air filter, or COBB intake system
Exhaust requirements: Stock exhaust, or COBB catback exhaust system
Stage2 Maps
Intake Requirements: COBB front mount intercooler or equivalent and COBB intake system or equivalent
Stage3 Maps
Exhaust requirements: COBB catted downpipes or equivalent and COBB catback exhaust system or equivalent
Hope that helps,
Mark
Your preference, once it's flashed it's done. Most of us keep it mounted to monitor gauges and health of tune and fuelOne last question after you load the tune do you need to keep accessport on mount or can u keep it in glovebox unplugged I don't want it stolen?
So it stays on ecu once it's unplugged? I will do that while driving but if going to be parked I wanted to lock it upYour preference, once it's flashed it's done. Most of us keep it mounted to monitor gauges and health of tune and fuel
The tune file and firmware is indeed flashed to the ECU. Post-flashing, the AP becomes a real-time monitoring tool and log file collector. So the car runs no differently post-flash with the AP connected or disconnected.So it stays on ecu once it's unplugged? I will do that while driving but if going to be parked I wanted to lock it up
