Hey guys, I ordered a Steeda spring for the FoST. I'm excited to try it out, but I broke my housing removing it from the car. Is there a way to get another one without having to purchase the whole assembly? Thanks.
You have to purchase the whole clutch pedal assembly or find someone selling just the plastic piece. Unfortunately ford does not sell the piece separately for whatever reason.Hey guys, I ordered a Steeda spring for the FoST. I'm excited to try it out, but I broke my housing removing it from the car. Is there a way to get another one without having to purchase the whole assembly? Thanks.
Check out your local pick-a-part yard.Hey guys, I ordered a Steeda spring for the FoST. I'm excited to try it out, but I broke my housing removing it from the car. Is there a way to get another one without having to purchase the whole assembly? Thanks.
Same thing happened to me. Anyone know how much Ford wants for one?Hey guys, I ordered a Steeda spring for the FoST. I'm excited to try it out, but I broke my housing removing it from the car. Is there a way to get another one without having to purchase the whole assembly? Thanks.
Were did you get it amd part # pleasePost 673 from this thread...
http://www.focusst.org/forum/focus-...s-focus-st-have-assistance-clutch-spring.html
Technically for the RS and not the ST, but it appears to be the same housing. I have one on order for when my Steeda spring comes. Would rather have it just in case.
I cancelled my order before it came in, but I believe the part number is AV6Z-7534-A. I had ordered from AutoNation Ford, but any Ford dealer should be able to get it.Were did you get it amd part # please
Mine is a 16 st do you know if includes plastic pieces. Dealer around here says have to order whole clutch arm kit.to get it.I cancelled my order before it came in, but I believe the part number is AV6Z-7534-A. I had ordered from AutoNation Ford, but any Ford dealer should be able to get it.
Based on the other thread that I mentioned before, it is supposed to include the plastic pieces. If your dealer is looking at the ST, then it is going to show the whole clutch kit. The Part number I posted is an RS part number, but should be the same spring (again according to the posts of others here ad not my personal experience since I did not end up needing/receiving one).Mine is a 16 st do you know if includes plastic pieces. Dealer around here says have to order whole clutch arm kit.to get it.
Could you expound on this method? I already broke one and am trying to decide to go with the very expensive assembly from Steeda or try to take another stock one apart.vice and a pickle fork... for when you try it again
sure i can try...Could you expound on this method? I already broke one and am trying to decide to go with the very expensive assembly from Steeda or try to take another stock one apart.
Thanks.
