1 - 11 of 11 Posts
Has anyone had any issues with injectors clogging or failing? I've gone though 2 brand new injectors, both in cylinder 3.
(13ST 55k)
brake fluid is your friend, cleans everything.
And ruins rubber. I would never use brake fluid to clean anything, it leaves a nasty film too. Brake cleaner is better, but still not a decent choice.
You could soak them in fuel (natural solvent) or injector cleaner.
Just out of curiosity, did the car just stall out? Were you just cruising when it happened? And like above, were you getting any odd corrections or anything? Interesting, because this is one of the leading theories to the engine failures
Discussion Starter #9
I was cruising to lunch, and I had the ac going. Then it started to stall out.
Discussion Starter #11
Interesting.. When you say you got retuned, was that before or after the new injector? Also, do you run any type of ethanol blend?
Sweet looking ride btw
I put new injector in right before the new tune. Just 91.
Thanks, I love my car.
1 - 11 of 11 Posts
