1 - 10 of 10 Posts
check engine light popped up last night. I ran a crackle pop tune for a week then i took it off a couple weeks ago and went back to normal (no tune). should i be worried or can i drive on this to work?
2017 Kona Blue ST1
Could be a bad or damaged wide band O2 sensor or you could have an issue where the engine is running lean. We need a lot more information inorder to help.
Reactions: junits15
鈥13 Focus ST3, Tuxedo Black
Are you catted?
2017 Kona Blue ST1
How long did you run it for?
2017 Kona Blue ST1
Without getting into a lecture (rant more likely) about this tune regardless of the DP configuration first we need to determine if the sensor is damaged or if you are experiencing a fueling issue.
Please give us more information about your configuration. Mods, tune, etc.. there's not enough information to help.
The Wideband O2 is a critical component and you should consider fixing this before driving around to prevent damaging the engine.
all i鈥檓 running right now is a blow off valve, cobb intake, res and muffler delete. I ran the crackle pop tune for one week and that was 2 weeks ago. I took off the tune because i don鈥檛 have a catless downpipe
2017 Kona Blue ST1
Year and mileage.
1 - 10 of 10 Posts
