1 - 4 of 4 Posts
Hey all,
First of all I have done my best to search the forum and web for helpful answers to this question to no avail. I have a 2016 ST1 and my check engine light has come on. I attempted to find the DTC code through the TEST menu interface with no codes found. I am at 11k miles and am due for an oil change. Is the oil change indicator the check engine light? Is the self DTC check reliable? I have seen that there are other status messages by looking through the forums that pop up but i wasnt certain if that was exclusive to other models. There are no noticeable performance changes nor were there any events that prompted the light. I just turned it on to go home from work and it was on. Earliest i can get it to the dealership is Monday.
Thanks
You could stop at your local auto zone or other auto parts store and they should have a code reader you could use.
I've never used the test menu for checking engine codes so I can't comment on it's accuracy.
1 - 4 of 4 Posts
