As the title states, I have a check engine light after everything is up and running.
Codes as follows:
P0135 (this pops up first, its the upflow sensor)
P0302 (cylinder 2 misfire
P0303 (cylinder 3 misfire
P0304 (cylinder 4 misfire
I did have a P0316 but that didn't show up on the Auto Zone scanner, but i'm taking that as a grain of salt, however the Access Port read's the P0316 (misfire after 1000 revolutions) so i'm going off of that.
Let's go through what i've had done shall we?
Accel coil packs, new crank sensor, new ITV 24 plugs, internals, PVC system, oil catch can, wiring harness was not touched except for the recall splice, catless down-pipe with exhaust system, EFR turbo and pipes, battery cables tightened down.
ECU just has Stratfield tune on it. (thank you)
Exhaust smells rich, but with no smoke coming out of it. I assume its do to the break in tune.
Going to change oil here in a few days.
Thank you for reading! Comments, questions, suggestions always welcome.
Codes as follows:
