I was curious about how much heat was being contributed at each stage in the induction process, so I grabbed some datalogs last week and did a bit of analysis. If I've misunderstood any of the temp sensor locations or my analysis is wrong, I'd be happy to be corrected by someone more knowledgeable. Looking at you, Randy.
Background for the graph below:
- Car has FRPP intake, Corsiar/BREEDT intake runner, and FSWERKS 93 octane tune named "FSW8HSc beta for intake spacer".
- Ambient air temp was 63F on day tested. Don't know humidity, but it was low.
- Due to circumstances, the run was started with a 90 degree right turn onto a highway. This was not a run for maximum speed.
- The car was warmed up (coolant at 189F) but driven gently prior to run.
Looking at the raw values was more confusing than necessary for the data I wanted in this particular case, so I derived some values:
- Engine RPM as % of Redline (defined as 7000 RPM), in order to avoid a second Y axis
- Pre-Filter Intake Tract Heating = Intake Air Temp - Ambient Air Temp
- Post-Filter Intake Tract Heating = Compressor Inlet Temp - Intake Air Temp
- Compressor Heating = Compressor Outlet Temp - Compressor Inlet Temp
- Intercooler Cooling = Compressor Outlet Temp - Charge Air Temp
- Total Heating = Charge Air Temp - Ambient Air Temp
And now the actual graph with analysis (some of which could be erroneous). I barely had time to get into third gear, so I know this graph is a very small window and I will do some longer and better-planned runs with the same PIDs logged.
