Not necessarily true. I have the steeda 1 piece mount with the "street" set of bushings installed. I rode in my friends with the cpe two piece mount and it almost felt like his had less vibrations. Also could be because I was in the passenger seat vs. the driver seat, but none the less. They both had vibrations. I also removed mine after installation, and re-torqued everything to spec just to make sure I installed it properly, and it didnt really change at all. I've learned to get used to it. I may switch to the "Race" bushings in the future because if im going to get the vibrations, i might as well get all the benefits of the motor not moving around on me and less wheel hop.NVH is highly subjective. One person's "slight increase in vibration," is another person's hell. I have the CPe Stage 2 RMM. Everyone said, it's mild. F that. I'm pushing 40, I should have known better. You never get used to it, it's there, you will feel it in lower revs, or coming off from a stop. But only from a stop, not during driving.
Are the normal RMM's better (i.e. stage 1 esque? Probably. They are only replacing 1 bushing, not two.
Mountune's seems to be highly rated. But again, NVH is highly subjective... IF I had to do it over, I'd probably go that route, and sell the CPe and break even.
I like the CFM myself; I noticed no added vibs after installing it, but I was replacing the e-Focus mount and already had both Turbo Tech uppers, which shake pretty hard at low revs.Trying to decide between the CFM and the Mountune myself.
If you want to get rid of your cp-e, I'll swap with ya =)
I had the e-focus RMM only and switched to the CFM with all 4 pins. Noticed a little bit more vibes initially. It wasn't bad IMO at all (subjective). After a while, it broke in a bit and I don't notice any vibes at all. Considering buying/putting in more pins. It's worth it IMO.so many of you say the RMM is great, but many also say it vibrates like hell... this is a daily driver, so recommend?
they're on sale till tomorrow![]()
When they break in and the vibes start going away, do the symptoms we're trying to correct with a stiffer RMM start coming back?I had the e-focus RMM only and switched to the CFM with all 4 pins. Noticed a little bit more vibes initially. It wasn't bad IMO at all (subjective). After a while, it broke in a bit and I don't notice any vibes at all. Considering buying/putting in more pins. It's worth it IMO.
No...."shift bang" is eliminated. Feels more "planted" as well.When they break in and the vibes start going away, do the symptoms we're trying to correct with a stiffer RMM start coming back?
