The factory rear control arms have an eccentric built in that gives some camber adjustment but allows no toe adjustment, limiting your alignment possibilities. CFM Performance adjusters replace the frontmost rear control arms and gives you the adjustability you need. CFM Performance adjustable toe adjusters utilize high quality QA1 rod ends to provide reliability and durability.
Head over to CFM Performance Rear Toe Adjusters for 2013-15 Focus ST/ST250 and grab yours today!
QA1 Rod End Features:
2-Piece - carbon steel - Teflon®/Kevlar® Self-lubricating race right & left hand threads.
Ball
• 52100 Bearing Steel.
• Heat Treated.
• Hard Chrome Plated.
• Precision Ground.
Race
• Teflon®/Kevlar®
• Self-Lubricating
• Self-Sealing
Body
• Carbon Steel.
• Protective Coated for Corrosion Resistance.
Exclusive Features
• Metal to Metal Support for Heavy Shock Loads.
• Increased Cross-Sectional Thickness for Greater Tensile Strength.
