21 - 39 of 39 Posts
Hey Chris, how much vibration transfers to the cabin between no spacer vs the 4 spacers? I'm wanting to reduce the wheel hop, obviously, but I don't need to piss the wife off with noise and vibes(the bad kind)
Darth
Discussion Starter #30
Darth
@DarthGinger the mount's minimum setting is 2 pins @ 12 o clock. Most people seem to compare the 2 pin setting to the efocus mount. With the 4 pin set up (most common) usually you will only see minimal vibes with the ac on at idle.
Just ordered!
Not stiff enough for ya? How long did it take for you to install it?
Install takes me about 45 minutes start to finish, but I have done it a couple time before. It works well with 4 pins, I just want it to work weller. I'm thinking 3 more pins will do it, leaving 2 empty holes for a bit of cushion.
Ah, I gotcha. I always want my aftermarket parts to work a lot more gooder than the stock ones. Test drive time
21 - 39 of 39 Posts
