I'm going to send out the BT and EWG pipe for ceramic coating before popping it in.
What all should I ceramic coat on it? Just the hot side?
Would it make sense to have the cold side done just to protect from corrosion? What about the elbow (again, I assume it would only be to protect from corrosion ... if that's even needed).
Lastly, just the outside, right? And the ceramic used on the hot side would be different from the cold (to support the heat difference, I assume)?
Thx!
Thx!
