Car throwing P018B and P008B, not sure where to start fixing
1 reading
9.1K views 6 replies 4 participants last post by  focus_138
#1 ·
Hey y’all, so my car has been throwing P018B now for a few weeks and I haven’t be able to figure out what’s wrong with it. It drives fine although occasionally on high acceleration it feels like it dropped all of its power mid gear. Car has thrown P008B low pressure fuel - to high, cleared it and it came back after 2 weeks last night. Anyone have any idea with what I should start looking at?
#2 ·
First you need to inspect the fuel tank for deformation due to a failed purge valve.
The EcoBoost has 2 fuel pumps (3 on the RS models) 1 HPFP (high pressure fuel pump) & 1 LPFP (low pressure fuel pump.
The low pressure side is controlled by a FPCM (fuel pump control module). It is monitored by a sensor located in the just behind the engine on the firewall on the low pressure fuel line.
This low pressure system feeds the high pressure pump that is mechanically driven by the exhaust camshaft. This pump is controlled directly by the PCM to add pressure. Note this pump cannot decrease pressure only increase it.
The HPFP feeds the fuel rail located under the intake manifold and is monitored by a sensor on the rail located on the passenger side.
Do you have a way to monitor or log your high and low pressures?
Reactions: W4R
