Lately I've noticed that when i brake moderate between 45 mph highway speeds my car pulls to the left. If i am hands off the wheel to diagnose, my steering wheel then turns to the right, moving my car to the right.
2013 ST2, only brake upgrade is Hawk HPS pads. I am running 17" Blizzaks on aftermarket rims. Cold tire pressures set equal all positions. It did not seem, or i did not notice this, when my summer setup was on.
If I am in neutral, it seems worse than if I am braking in a gear.
Alignment check was good, all brake hardware torqued to spec.
I measured rotor and caliper temps the other day, the left rear was slightly higher than the right rear (maybe 20+ degrees) however the front caliper and rotor (measured at same spot both sides) was around 50. I know Ford uses the brakes to mitigate torque steer, however getting the brakes warmed up was simply braking off the highway, no hard acceleration.
I've been chasing this for about a month now, and my next attempt to fix will be greasing the caliper slide pins (just did it before winter).
Has anyone else experienced this?
