241 - 259 of 259 Posts
Discussion Starter #241
I got a few things in the past week. I am so excited that this is coming together. Also just ordered the turbo kit. So hopefully that will be on the way soon to on about 2-3 weeks for Speed3Performance. It is a PTE 6062.
Here is the ARP Main bolts and cam bolts.
378629
Also ARP 625+ Head studs. This will really keep everything tight hopefully lol.
378630
378631
378632
378633
378634
Got a Supertech head Gasket. Was one of the only ones that I could find that actually says it is good for 32 lbs+ of boost.
378635
Discussion Starter #242
Here is the Radium Engineering Breather Plate. I will say that the quality of this piece is absolutely amazing. I really think now that after seeing the OEM one that it would have been leaking boost everywhere. Only a little bit of assembly required. It was fun to put something together for once for the car. Also came with a really sweet sticker.
378636
378637
378638
378639
378640
378641
Discussion Starter #243
Got the Damond Big Throttle Body kit in as well. I was surprised they where able to fit everything inside of the box. But non the less it all came in nicely protected. Best part is I found a little note on the top of the box that just shows how much they care about there customers and the products they have. I will have to purchase longer bolts because of the Boomba throttle body spacer.
378647
378644
378645
378646
Discussion Starter #244
OK guys so here are a few updates. Dropped the motor and head off at the machine shop last week so while that is being worked on I am tearing down the trans to upgrade the syncros and install my Mfactory LSD. I am just waiting on a those reverse thread bolts to come in and I will be able to tear down the gear sets and put them back together in one day to limit confusion lol. Everything motor wise has arrived except for a custom second oil chain guide from speed performance. Also speaking of them they are in the process of cleaning my injectors and building the 6062 turbo kit. My plan was to have this motor in by August. It seems to be that the end of this month or mid June is now very realistic. The only true things I really need to do after getting the motor back into the car is 0 out my Split second controller, update the accessport, and order a new tune with Alex from Stratified. After the motor is broken in I will be installing the Radium fuel kit and Walbro 450LPH Fuel Pump. The fuel level sensor went bad before the head cracked so that will be replaced as well. I will have more pictures and such for everyone soon!
Discussion Starter #245
So I decided to take the motor out of the shop it was in. Over 2 months and still no ETA when it was going to be started or finished. I picked it up and I took it up to the guys at Speed Performance to build. I was there for a few hours talking to them about the build and there where a few things that I decided to change. We changed the head from a 2.0 head to a 2.3 head and I am removing the WMI system from the car. The fuel pump will be a Walboro 525 instead of a 450. Fuel instead of an E50 mix will be an E85 mix. I was told 2-3 weeks to get the motor done and they will mount and block off any holes for the turbo kit. I would usually do this myself but since its all there I figured just to let them. We discussed a few other things that I will be replacing as well that will be brought up in the next post. I got to talk to Nishan as well and he will be handling my cars tuning from here on out on a dyno of course. I am still predicting the end of July to have the car back together and working as long as everything works out. I also got the trans back together and sealed. Hopefully, everything is put together right.
Discussion Starter #246
I have a few pictures of the bottom end from SpeedPerformance. I also have a picture of the PTE 6062 GEN 2 turbo. So far it has taken them less than a week to get the bottom end together. The 2.3 head is also almost done! I am being told this week or next week at the most and it will be ready for me to pick up and put into the car. I am super excited and I can't wait.
380148
380149
380150
Discussion Starter #247
Little update here. I want to start bt saying SpeedPerformance has been great to work with. My motor is still not done and we have been just waiting on the 1/2inch head stud nuts and washers and then it will be finished and ready to pick up. I hate all of this waiting lol. the end of car season is right around the corner now. I will hopefully update you guys with some pictures of the motor done and ready to get in the car. Also, I hope the trans will hold together. I tried to be as precise as I could be when I put everything back together. I am hoping to see 700+ WHP or so still. Sidenote, the RS drivetrain swap is seeming more a reality than a dream. I will let everyone know more about that soon.
Discussion Starter #248
So huge update. I got the motor back from speed. One big thing is that we upgraded the turbo to a PTE6266 Gen 2. It was going to be a 6062. Motor looks fantastic. Strapped it up in the truck and drove 3 hours back home. Put it on the crane adn immedittly started working on it.
381963
381964
Discussion Starter #249
Started with the easy stuff and then just started putting everything back on from inside out.
381965
381966
Flywheel and pressure plate went on easy. Everything torqued down and orange thread locker used.
381967
381968
Reactions: W4R
Discussion Starter #250
Now the hardest part was getting the trans lined up and mounted. I choose to do this out of the car for simplicity. I wanted to make it as simple as I could put everything back into the car. Anyway, as you can imagine it was hard todo. Had the trans lifted to the engine on the crane. Once getting everything lined up it wasn't that bad. Just had to put it all on evenly.
381970
I put the rest of the accessories on and then plopped the axles in. Even filled up the trans too!
381971
381972
381973
381974
Now, I am just waiting on the turbo manifold bracket, and the 8 port AUX fuel rail and 525 Walboro Pump. Bought all the oil needed for break-in, coolant, and a few vacuum blocks from Damond Motorsports to help clean up the vacuum lines. When I get the turbo manifold bracket I will open up the turbo and start posting up pics for everyone to see! I am super excited and can't wait for the car to run again.
Discussion Starter #251
Just a little update. The motor is in!!!!!!!!!!! Finally got the final things last week. It started right up. Trans works flawlessly so far. The car feels great even though I have no boost right now as I can't boost for 1000 miles 150 miles are already gone through. I will have to update it soon with the pictures and videos that I have of it so far.
Thats weird. I'm a motoman break in guy.
Also, geez took long enough.
Are you remote tuning with Nishan? Or is he still taking care of family?
Moderator
Same. I read an article from a motorcycle engine builder years ago that had comparisons of engines that had easy versus hard break-ins, the pistons were noticeably cleaner with the hard break in. First 20 minutes is crucial.
I was taught, way back when, that you need to stretch an engine out fairly frequently when breaking it in so that the rings make it as far up into the bore as they will once broken in. Forming a ridge too low in the bore can be quite hard on the compression ring.
Discussion Starter #255
They want you to do a lot of vacuum pulls and that will suck the rings into the bore and create a much better piston ring seal.
Discussion Starter #256
Little update. Car makes boost now. Still on the base map. Nishan limited boost with the throttle position sensor to 12 lbs. Went ahead and put 18 pound wastegate springs in the wastegate as he instructed. I am dropping the car off Monday 11/9/20 to get the fuel system in and later Nishan will tune it. Car will have a 93 tune, E50 tune and E70 tune. Anyway the base tune drives great. Just as good as my old custom tune. I am really excited to see what the car will make. Can’t wait to drive her.
Also HUGE news. Working with air lift performance for a sponsorship. That is going very well. The one off Eibach coils are starting to leak and Eibach can only rebuild them once. They have no more materials afterwards. So I am
Going a different direction with suspension. Airlift said that we can dial in there suspension to handle the power better than the coils. I guess we will have to wait and see.
So you broke the 10k dollar mark for this rebuild yet?
Discussion Starter #258
Discussion Starter #259
Car is dropped off at speedperf6rmanc3. Tuning will be happening hopefully this week. Possibly Saturday. They are putting there 8 port fuel rail in. Also huge news!!!
I have got a new sponsorship!!!!!!
Airlift Performance is sponsoring the car. If anyone wants some limited production eibach coilovers let me know! 500 bucks. Anyway It’s there 3H kit with two compressors and a 4 gallon tank.
