Pull the ac compressor stud, I think its a 4mm.As the title states, I'm doing a bsd install right now, and I'm having some trouble dropping the pan. Any help or advice would be greatly appreciated. Thanks!
Well, there is noticeable vibes, very noticeable if you have full mounts. The car does rev a bit faster though, so mission accomplished. I think I have like 20,000 miles with my BSD. Maybe even more at this point.Report back with how the car performs after you have it all completed. I am interested in doing this myself but am worried about excessive vibration and if the performance improvement, if any, is worth the work.
Listen to this guy, he knows all about the good car vibes.Well, there is noticeable vibes, very noticeable if you have full mounts. The car does rev a bit faster though, so mission accomplished. I think I have like 20,000 miles with my BSD. Maybe even more at this point.
Its not for "sensitive" people, thats for sure.
Vibes are extremely tolerable, I haven't really noticed anything excessive after ~200 miles. Definitely revs faster, easier to rev match, and it doesn't hang anymoreReport back with how the car performs after you have it all completed. I am interested in doing this myself but am worried about excessive vibration and if the performance improvement, if any, is worth the work.
I take it you are on stock motor mounts?Vibes are extremely tolerable, I haven't really noticed anything excessive after ~200 miles. Definitely revs faster, easier to rev match, and it doesn't hang anymore
I'm running the Jbr kit with the baffle, I'm on the e-focus rmm right now, plan on doing the Jbr 88 within the next few weeks. Nvh really doesn't bother me too much, I drove a wrangler before I got the FoSTI take it you are on stock motor mounts?
I happened to be on full motor mounts (TTR PSMM +DSMM and CPE stage 2) before I did mine, there was quite the difference with the BSD. And it sounds like the car is going to explode when you decel in gear from like 3k rpm down to 2800rpm iirc.
Did you get a baffle?
Im running the Massive Speed with Baffle.
