Before anyone says anything: yes. I used Google to search for threads on this topic and came up with only a couple, some of which helped me. Anyways, here goes.
I'm very new to car maintenance. That being said, spark plugs should be an easy install, no? It went very smoothly until I got to the far right cylinder (when facing engine bay from front of car). I've got Cobbs intake, so that far right spark plug is only accessible by unbolting and pushing the intake tube back to twist out the coil. After unscrewing the stock spark plug, I coated the new one in anti-seize, then tried to install it. But the spark plug would not sit in the threads straight. Let me break down the process I went through:
1. Put new plug in about 1/3 of the way. Very hard to turn, so backed it out.
2. Tried a different plug just to be sure it wasn't the threads on the previous plug. Same result.
3. Tried to put the plug in again, keeping it as straight as possible. (This is where my inexperience got the best of me). Started torquing plug harder than I should have, heard what I now believe was the porcelain cracking. Backed plug out, inspected for damage, found nothing.
4. Tried to install same plug again, keeping it as straight as possible. Figured it was just hard to turn (again, inexperience got the best of me). Torqued so much that porcelain ended up breaking off of the top, and is now sitting on the edges of the spark plug and the hole (with the hole still plugged). As far as I know, nothing went into the cylinder. I, of course, will check to be sure if I'm able to get the plug out after I get the pieces out.
My question: Do any of you believe the spark plug hole is cross threaded for that cylinder? Or does it just require a bit more finesse than the others? NONE of the new plugs would go in straight, meaning I would have cross threaded it when pulling out the stock plug, which I find hard to believe.
I've read about retapping the hole for new threads, but will not be attempting that. I barely trusted myself to do spark plugs, and you can all see how that turned out. If it's cross threaded, to the shop it goes (ugh).
