I have a 2015 Focus ST 3. Prior to purchasing my Brembo brakes from the dealer I had asked what offset my wheels were. I have the double spoke black 18" wheels and I was told 55 offset the same as the snowflake. Upon doing more digging, I saw that one ST owner was using 5mm spacers to help clear the Brembos. Well after install the Brembos and H&R wheel spacers 5mm I went to install one of my wheel and it doesn't fit. As a matter of fact, the one caliper got scratched pretty bad along with the inside of my wheel from simply trying to center it on the hub. So clearly there is an issue here, either you need more then a 5mm spacer to clear these calipers or my offset isn't what I was told. I need to finish my car asap plus now fix that caliper on top of it.
Please HELP!
Please HELP!
