1 - 2 of 2 Posts
Imgur: The most awesome images on the Internet
Brakes failed on track, as you can see the caliper got so hot, the piston melted, and the red paint melted away as well. upgraded to Brembo 4 piston calipers, plus Brembo slotted disk on the front, and EBC rotor with yellow stuff pads in back.
wheels didn't fit over the Brembo calipers, so hat do go with 25 mm Eibach spacers. wheel are further out then i would like, but i have not noticed any rubbing so far, and the car stops on a dime!
if you are tracking the car i highly recommend a good brake upgrade
What wheel size do you have? Would a offset of 45mm be enough? I start to think that the Brembo 4-piston kit which Steeda sells for example could be the same which is mounted on the RS.
1 - 2 of 2 Posts
