releasing Air into the air is BAD!!!! CA will never allow it so I highly recommend not installing this on a car that need CARB compliance!are any of these CARB compliant?
LOL air into the airreleasing Air into the air is BAD!!!! CA will never allow it so I highly recommend not installing this on a car that need CARB compliance!
what do you mean improvement? there isn't "improvement" going to anything. these are 100% noise makers and will not add 1HP or 1/2lb-tqLOL air into the air
how about BPVs? any improvement going with one of those?
meaning will they hold boost longer than stock? or better?what do you mean improvement? there isn't "improvement" going to anything. these are 100% noise makers and will not add 1HP or 1/2lb-tq
BPV is what is in the car and a aftermarket is a another piece of metal other than stock doing the same thing.
I haven't seen proof anywhere stating that they do. but I have heard of aftermarket ones failing and causing issues. likely from improper installationsmeaning will they hold boost longer than stock? or better?
