1 - 5 of 5 Posts
i have problem with my wastegate solenoid and bypass valve control. I change the map to different slot and dont past 6 psi.
Code P0035 P0034 P0245 P0246
Is the vehicle still under warranty? I'm not the best to advise on this, but doesn't sound like a cheap fix. Either turbo, wastegate, or worse. If it's under warranty and you're not heavily modded, take her in.
I dont have warranty.... i buy a new solenoid and continue with the problem i also check the solenoid that is over the turbo and is ok ...
so the car was acting fine, then you switched to a differnt map, and THEN it started only making 6PSI max boost?
if so, I would talk to your tuner.
1 - 5 of 5 Posts
