It has a brand new WG solenoid, and new lines for the WG solenoid.I only have the WG solenoid hooked up to the wastegate, the compressor side of turbo, and vent to the intake.
Pressure tested the system to 45lbs of air from a compressor. No leaksI doubt there is a controls issue, I had a friend with this issue and he hunted everything for awhile. He finally just went through and reseated all of his charge pipes and it took care of the problem. If one pipe came off another one could have came loose. Cause and effect here is the way I would look at it rather than jumping into other areas.
Boost leak was done to 45psi, from a air compressor.The PCM isn't calling for 29 PSI.
Check to see what your Barometric pressure is on the AP and use it to determine what the PCM is commanding.
When you say to boost leak tested the system what PSI did you check it to? You want to shoot for above your target boost pressure.
Your old logs were hitting 29.46 PSI @ 15.34% WGDC so I know it was working.
But the PCM is only calling for 38.94 PSI (24.4 PSI).Pressure tested the system to 45lbs of air from a compressor. No leaks
Pressure 14.39The PCM isn't calling for 29 PSI.
Kam was reset.But the PCM is only calling for 38.94 PSI (24.4 PSI).
Have you reset the KAM?
It may have been, WG does function, have pulled it off the car multiple times since this started. It could just be a hole was in the WG lines causing the "overboost". But if it were overboosting why would JST say the logs looked good? Im not sure.The PCM isn't calling for 29 PSI. Was it an overboost condition that blew the charge pipe off? Have you checked WG function?
by good did you mean the negative corrections on 1 (-2.94) & 4 (-2.49)?It may have been, WG does function, have pulled it off the car multiple times since this started. It could just be a hole was in the WG lines causing the "overboost". But if it were overboosting why would JST say the logs looked good? Im not sure.
Charge pipe blew off, did not make any boost pressure. Put the pipe back on, made the 16psi of boost. Then replaced the WG lines, then the solenoid, then pressure tested the system.
yep. He just wanted longer datalogs showing more of the RPM.by good did you mean the negative corrections on 1 (-2.94) & 4 (-2.49)?
^^^^ What he said. No way was that thing making 29 psi at 13% WGDC unless something was hooked up incorrectly/you had a part failure causing an overboost problem. On my 2867, when Brian had it set to 15% or so WGDC, it wasn't making much boost at all (like 16 psi maybe?), but I also had everything hooked up correctly and didn't have any parts failures. At 75% it was hitting around 28.5 psi before the tires broke loose in 3rd, so I could see 29 psi at 75% WGDC... but 13%... no way... something is screwy.So you were making 29 PSI with only 13% WGDC on the original logs. Now you're only makes 11 PSI (PCM commanding 25) at a 65% duty cycle and the tuner is adding more?
Something is definitely not adding up here.
So the only thing that I can say is that one of the wastegate lines had a hole, or the controller was bad. So that the boost level was way over the wgdc. When I took the line off the wastegate. Just letting it do what it wants to do it made 29. So something was broken with the boost lines or the controller.So you were making 29 PSI with only 13% WGDC on the original logs. Now you're only makes 11 PSI (PCM commanding 25) at a 65% duty cycle and the tuner is adding more?
Thanks again for the help.It hit 29 PSI and the TIP Desired was around 43 so it was dead on target.
The second was only commanding TIP Desired around 25 and it was hitting 11 which is correct.
Hope you get it all straightened out. Don't forget to keep an eye on those negative corrections.
J
