Hello, all. Having some issues with my car, and unsure of the cause. (my car is built for this power level, with all supporting mods)
A little backstory swapped out my old turbo gtx3071r with a g30-660. (internal wastegate went bad, not enough top end power). Getting tuned through JST. Everything was great until one of my charge pipes popped off, after this i had this issue of lower boost. Previously on the same tune I was hitting 29.5, now I am lucky to hit 17psi. I replaced the boost control solenoid, pressure tested the system up to 45psi, no leaks. Just tested the voltages going to the solenoid, got 12VDC to the gray wire, and the blue-red one was getting 3.46VDC when the key was on, engine not running. The wastegate is a Turbosmart Compgate 40, with a 17lbs spring setup.
I also unplugged the electrical connector to the boost control solenoid, and the issue almost was the same.
Unplugging the line to the wastegate gives me 29.5lbs of boost. So I do not suspect the wastegate to be the problem. This is how i have the wastegate setup. with proper boost lines. (I replaced the lines as I though they could have been the issue, no cracks splits or tears in the old lines)
Thank you everyone for the help!!
