1 - 4 of 4 Posts
Today i was driving around and the car felt slower than i was used to. I have not seen this issue yet, and I have had the car almost 3 months now and driven it almost everyday. I noticed that the car was being limited to 1/4 of the boost gauge 6.24lbs. the car was fully warmed up it was about 64F out overcast so it was just an odd thing. Will the ecu limit boost if charge temps are to high? The problem went away after i pulled over in a parking lot shut the car off took a peek under the hood to see if anything was out of place, and all looked fine. I then fired the car back up and drove off, and had normal boost back around 12.5-16 lbs when full throttle. Anyone else have this happen?
6.24lbs was the max boost I could get in any gear and through the whole rpm band. Even tried esc in sport and disabled.
Do you have an accessport?
1 - 4 of 4 Posts
