Current mod list:
AEM dryflow filter
Mishimoto Intercooler w/ hot/cold pipes
2.3 Mustang throttle body
Borla catback w/ Cobb hangers
NGK Ruthenium step colder plugs
CFM valve cover breather
ST Suspensions rear sway bar
Konig Hypergrams / Michelin PS4S
Option Lab R555 / Michelin AS3+
Mountune:
-RMM
-Intake
-BPV
TB Performance:
-front and rear traction bars
-strut tower brace
-cross member brace
-mid chassis brace
-master cylinder brace
-rear end-links
Boomba:
-OCC
-symposer delete
-hood release
-RS shift lever
-shifter base bushings
-trans cable bracket bushings
VelossaTech:
-Gen3 snorkel
-diffuser fins
-wing risers
Steeda:
-jacking rails
-drain plug
-interior hood latch
Shift Solutions 400g CS knob
Alex the Machinist shifter cable bushings
Clutch Masters braided clutch line
Motul DCTF
JBR gas pedal spacer
MELE battery box / XS Power S680
Hella Supertones
Spec-D smoked tailights
Headlight Armor GT yellow fog overlays
Lamin-X 3rd brake light tint (FSwerks)
Anchor Room side marker blackouts
Rokblokz shorty mudflaps
Perrin 2" shorty antenna
Infinity Primus 6510cs speakers
Rockford Fosgate 8" shallow mount subwoofer
Diode Dynamics LEDs:
-SLF yellow fogs
-side-mirror
-trunk
-visors
Year 1 summary:
1. Signed lease w/ 90 miles on odo, got sidewall bubble in a tire after 100 miles. Dealer service manager said tire is special order and will take at least a week and I had to leave the car. Ordered Pirelli p-nero shipped from TireRack to dealer next day, showed service manager spare in trunk to put on, came back next day and Dealer mounted tired for free but scratched up rim, no action taken.
2. Discovered wheels/tires not covered in maintenance plan sold at signing. Fought to get plan refunded and reduce monthly payment amount, resolved to do my own work or go to my mechanic friend.
3. Hood rubbing on headlights, took back to Dealer body shop to adjust, they found a rock under one headlight.
4. Around 600 miles noticed fuel line rubbing on symposer box bolted to battery tray. Factory had placed cellophane tape around the fuel line in that spot to protect and it was already scratched up. Blocked off w/ Boomba's delete and removed all symposer components, blocking firewall hole w/ included delrin plug.
5. 2000 miles: swapped stock air filter for AEM Dryflow.
6. Swapped out stock '15 shift knob for Ford '16+ ST3 carbon fiber knob
7. Installed Perrin shorty 2" antenna
8. 3000 miles: Oil changed to Pennzoil Platinum 5w30 + Motorcraft FL-400 S Filter using Rhino Ramps, all from Walmart.
9. ~3300 miles: After way too much deliberation with another brand, finally installed Boomba PCV catch can.
10. 3500 miles: Installed CFM breather cap. (bought used from forum member)
11. Was gonna install JLT on CCV side, but didn't want to cut sensor hose and couldn't source one w/ the sensor hose. JBR was gonna sell me a plastic adapter for $35, I passed after checking intake and not finding oil since installing CFM breather.
12. Got Fly5d floor mats, added Boosted Designs dead pedal, but Fly5d heel plate was plastic/thin metal and bent, went through 3 iterations of my own galvanized steel plate.
13. Installed Garageline accelerator pedal spacer.
14. Driver seat was clicking side-to-side, installed Whiteline lateral locks, problem solved.
15. Installed Rockblokz mud flaps (used from forum member)
16. Polyfilled subwoofer.
17. Applied RocketScience gold foil to airbox lid, and later to intake crossover pipe.
18. Clay barred and waxed.
19. Installed VelossaTech diffuser fins.
(continued)
AEM dryflow filter
Mountune:
-RMM
-Intake
-BPV
TB Performance:
-strut tower brace
-cross member brace
-mid chassis brace
-rear end-links
Boomba:
-OCC
-symposer delete
-hood release
-RS shift lever
VelossaTech:
-Gen3 snorkel
-diffuser fins
-wing risers
Steeda:
-jacking rails
-drain plug
Motul DCTF
Hella Supertones
-SLF yellow fogs
-side-mirror
-trunk
-visors
Year 1 summary:
(continued)
