Yeah. I did mine like the diagram though and later learned that you dont need to hook anything bakc up top. Diagram shold really be updated to reflect this. You'll need a cap with size 7/32 for the top.So can I cap off both lines coming out of the solenoid on the valve cover. I know one runs to the old bpv amd the other was for the boost side. Now I currently jave both the hard vaccum lines dangling.
No. Not enough vacuum to activate the BOV. CP-E had a special spring made for their exhale kit to run off of the solenoid. I think it's-3psi or something.Can you run the old BPV hose to the new BOV if you are already using the symposer delete nipple?
what is the other option if you are already using the symposer delete plate for an aftermarket boost gauge?
:whs: That'e exactly what I did on mine. Grabbed some "Ts" from Autozone. Unless you work at a machine shop and can fab up a block. CPE has one if you feel like dishing out $150.Just get a tee and tap into the line.
What did you end up doing? And what turbo are you installing?Hey guys I'm stuck. I did a big turbo swap and you guys are saying to cap off both hard lines on top of the motor?
Has your OEM failed?Sorry to bump an old thread. Is the boost control solenoid worth upgrading?
I see some people using this one. Is anything wrong with the OEM one?
