There isn't a focus specific one though, a turbo is universal pending you have the same flanges to mate the exhaust side to the mounting flange to engine head. And for our downpipe to work that is a vband mated section to the exhaust side that connects to our downpipe. To save you the headache go with a kit already on the market, but if you're dead set on a DIY then you have to make sure everything lines up, etc. You can expect if you want to push that turbo you need to build the motor for sure, because that turbo doesn't really wake up until the 400whp mark give or take and will feel a bit sluggish compared to a gtx2867r setup. So with that being said what are your end goals (power, drivability, etc)?Hey guys,
I am interested in going big turbo specifically a gtx3071r and was wondering if can use any gtx3071r or would only the one focus specific would work.
thanks
^^^ That x2, if you're set on going with that turbo.If I were you and had the budget, I'd purchase EFR Exhaust manifold and install it on the GTX3071 Turbo, the manifold it comes with is "airflow garbage" Also it distorts your Gasket over a short amount of time.
