I had a pretty big block of text here, but I didn't even want to read it all so here is the TL'DR:
I recently was driving with someone who was in a different big turbo Focus. He noticed a noise and said the other Focus did not have it. I thought it was just a quirk of the turbo and thought nothing of it until he mentioned it. I am planning on boost leak testing again but that equipment is two hours away in a frozen garage.
- Have a Mountune MRX Kit (BW 6258(a?))
- Had a boost leak test when installed, everything was perfect
- Swapped Injen exhaust with Milltek
- Noticed slight hum/whine/whistle coming from the firewall after Milltek install
- Can't hear it from outside
- Really only noticeable below 3k rpm, otherwise exhaust drones noise out
- Not boost dependent, happens in vacuum as well
- Doesn't sound like any boost leak I have ever heard.
- Car runs fine, boost still builds up quick and holds.
- No oil loss, smoke and no play in the turbo flywheel (Checked that last night)
It took me forever to catch it on audio, but you should be able to hear it here:
So until I get the motivation to sit out in a frozen garage: What do you think the noise is?
