In August of 2016 my wife got rid of her old rusted out Oldsmobile in favor of her first "newer" car, a 2012 Chevy Cruze RS with the 1.4 turbo and auto trans. She bought it CPO and had an additional warranty to over 100,000 miles. Its a really nice car and we both still like it, but her biggest complaint from the beginning has been how horribly underpowered the car is. These cars put something like 105 horsepower at the wheels and only make the situation worse by shifting at 6500 when the power falls off a cliff at 5500.
After 5 years and 80,000 miles of ownership its time to fix that. The stock turbo is probably better sized for a golf cart than a car engine, and they crack internally due to the extreme restriction where the 4 cylinders merge in the hotside. After some research I found ZZP makes their "Big wheel v3" turbo which is what we might consider to be a "hybrid" turbo in our realm. It comes with larger wheels than stock and it has a custom made-for-them hotside with a much larger a/r to help fix the cracking and promote better exhaust flow to the larger turbine. That was the end goal.
(Not pictured) last summer i scored a k&n cold air intake and BNR downpipe off craigslist. That got the ball rolling on the supporting mods. The car felt a little bit quicker on stock tune.
Over winter i adressed the stock intercooler (which is worse than ours) by installing a ZZP front mount intercooler.
Well fast forward not long ago, the car started losing power and setting p0299 underboost code. After inspection found the turbo had the dreaded crack. Its upgrade time!
Now all that was left to do was the turbo, 42# injectors and custom tune. Those were purchased last week and showed up Yesterday.
This morning i got aquainted with HPtuners, copied and emailed the factory PCM and TCM files to ZZP, and hopefully they will send me a base file monday.
Got the new turbo installed as well as addressed a few oil leaks and a coolant housing replaced at the same time.
ZZP shows this turbo making 235whp on ethanol, i'm hoping it'll do 200whp on 93, which is tremendous considering that'll be DOUBLE what it makes stock. Looking forward to the tuning process and seeing how this thing runs! Wife will be super happy i'm sure. I'll have to update with a video or two once tuning is done. Who knows, might even make a dragstrip pass as well!
