I'm sure there's different threads on it but what's the best or most recommended intercooler kit to replace on a 2017? Got stage 1tune, green filter and cp-e rmm, want to do the FMIC now and full exhaust next month.
Exactly so what's so wrong with wanting to keep the charge air temps in check with an intercooler upgrade? On hard pulls depending on ambient temps my charge air temps climb into the 170-190 range consistently.Steeda/CPe Lightweight handles larger turbos just fine, so will any upgrade over the stock unit. That said I've said it once I'll say it again, flow is not the issue with the stock intercooler, it's temperature control.
A larger turbo will have much lower outlet temperatures. So going BT is not the reason to base your upgrade around upgrading the turbo flow will not be exceeded, it will work fine. Almost nobody here is interested in the outer limits of output and the majority when they upgrade are only looking at GTX28xx which will not exceed the physical strength of the engine and unless you race it on slicks won't exceed the stock clutch either.
Okay but an upgraded intercooler on the stock turbo drops it down between 100-130 degrees. A larger turbo also drop it down to around 120-130 degrees. Before you overspend on an item please understand what your goals are.Exactly so what's so wrong with wanting to keep the charge air temps in check with an intercooler upgrade? On hard pulls depending on ambient temps my charge air temps climb into the 170-190 range consistently.
My goals are to keep the stock turbo and squeeze the most out of the car as I can while keeping temps in check and keeping the engine running in tip top shape. A big turbo upgrade is in the $2k ballpark range give or take. FMIC is in the $350-$550 range. So again tell me how im overspending to obtain my goals?Okay but an upgraded intercooler on the stock turbo drops it down between 100-130 degrees. A larger turbo also drop it down to around 120-130 degrees. Before you overspend on an item please understand what your goals are.
The constant pursuit of lower temps on the stock turbo is pointless, 130 degrees is fine. You aren't getting anymore out of the stock turbo. The majority of your gains come from ignition advance at that point, beyond the 20 hp or so you get from running an ethanol mix.
It's a good idea to get one. /endthreadMy goals are to keep the stock turbo and squeeze the most out of the car as I can while keeping temps in check and keeping the engine running in tip top shape. A big turbo upgrade is in the $2k ballpark range give or take. FMIC is in the $350-$550 range. So again tell me how im overspending to obtain my goals?
And by your point I should ignore replacing the FMIC and bump up to stage 3 and ignore the 180-190 degree charge air temps im seeing after a hard pull? Sounds good to me....opped out:
Also im not in the "constant pursuit of lower temps" all I'm wanting is to safely be able to run a stage 3 93 or e30 tune and from what ive read I will NEED a FMIC upgrade to do so. Again i have NO plans of going big turbo.
That is NOT my point. My point is one intercooler that brings temps down 120 degree vs one that bring it down 130 degree is of no consequence, IE it doesn't matter which one you choose.My goals are to keep the stock turbo and squeeze the most out of the car as I can while keeping temps in check and keeping the engine running in tip top shape. A big turbo upgrade is in the $2k ballpark range give or take. FMIC is in the $350-$550 range. So again tell me how im overspending to obtain my goals?
just ordered mine with their charge pipes a few mins ago!Id say highest roi is depo..... So do a bunch of other people on what seems like 1000 different best intercooler threads..... I'm satisfied with my 3.5 son of beast .
No, they are an absolute waste of money on the stock turbo. Stock charge pipes flow way more than enough for the stock turbo flow rate.The charge pipes seem to be pretty expensive. Are they needed if you not going BT?
I've seen a lot more expensive! and no, not needed at all, just don't like a couple of the restrictions that are in the OEM pipe where it necks down for a few inches. and I know that as soon as I get back from vacation in a couple weeks, I'll probably be ordering their catless DP. with how quickly its going to become stage 3 I know that will not be enough and will probably be saving up for a big(er) turbo upgrade pretty soon, so having it done now is just one less thing to worry about.The charge pipes seem to be pretty expensive. Are they needed if you not going BT?
