1 - 12 of 12 Posts
While I was checking the electrical grounds in my car in reference to this thread I noticed my battery cover was loose. When I opened it up I saw the following.
Vehicle Auto part Car Engine
Auto part Engine Vehicle Car
Doesn't look so good to me. Granted my car is a 2013 so the battery is sitting on 4 years. I was debating whether I should just clean it with some baking soda and water or just spring for a new battery.
The car was just at the dealership last week and they gave it a "clean" bill of health during their inspection.
dang.....4 years.......from what Ive read, must be a record. I replaced mine after 2 years......you are long overdue my friend. Read a number of posts in here of guys batteries dying after 2 years. Guess it somewhat depends on the climate. Older batteries corrode more but maintenance on batteries on the terminals is always necessary.
Yeah just looks like your battery finally died...4 years is a good life. You live in Texas though so you don't have to worry about winter lol. If you're cheap a cleaning would probably be a "get by" but it'll do it again and continue doing it. I'd just replace it.
New battery it is. For some reason I remember the other cars in the family never had battery issue till the 5 year mark which is why I thought it premature. I am a little ticked the dealership never spoke up though, I would have just shelled out the money last week to replace it.
Is there any reason to stick with OEM Motorcraft or is Autozone (Duralast) / Costco (Interstate) just as good.
LMStone I saw your work on the Odyssey battery. Looks neat but I just need this to work a few more years.
Stock batteries IMHO are fine for stock workloads of course! Yours lasted almost five years, right? :)
All the best,
Mark
Discussion Starter · #11 · (Edited)
Replaced mine as well before this winter, so only 4 years as well.
Remember to reset the battery monitor when you change the battery!
DIY Battery Monitor System Reset - 2013 / 2014 / 2015 / 2016 / 2017 Ford Escape Forum
I didn't realize I had to reset the monitor. I also seem to lack a USB to ODBII connector. Is this something I can coax a dealer to do for me or can I leave it be?
My battery hold down was pretty badly corroded so I'll probably slap on a new one from the parts department.
On a semi-related note. My car had been doing having the idle fluctuation and stalling issue regularly before I replaced the battery. Since then, it has been pretty steady actually (knock on wood). I guess simple solutions sometimes work best for electrical problems.
A dealer should DEFINITELY be able to do that for you, no questions asked. It's a very common process on new Fords.
Regarding the idle, when you have the battery unhooked it resets the keep alive memory (KAM) which makes the ECU relearn a lot of parameters. Not surprised it fixed the idle!
1 - 12 of 12 Posts
