1 - 4 of 4 Posts
This may be a dumb question, so I apologize in advance but I can't find the answer.
For the MP75 kit does the tuning handset need to be constantly connected or is it used to load the tune then disconnected? Basically, would I need to drive around with the handset mounted in the car?
Nope once the tune has been flashed to your ecu you are good to go. The handheld is good for monitoring the cars vitals and pulling codes but you dont have to keep it constantly connected.
You can load then disconnect. You don't need to drive around with it.
1 - 4 of 4 Posts
