1 - 20 of 21 Posts
Discussion Starter #2 (Edited)
Success! Also upgraded it all to Ver 3.4 and added a second USB port for the passenger. Big thanks to Brian Lovelace and www.naviupgrade.com for all his great guidance.
Anyone with an ST1 should do this!
380458
380499
380500
The final touch - A replacement SYNC badge for the console - no more "Powered by Microsoft" rubbish here! (This version of the badge can be sourced from a 2103-2016 Fusion console).
380564
2014 Ford Focus ST3
Congrats! Adding touchscreen makes interior so much better.
Reactions: StanE
2015 Focus ST
Did you order the parts somewhere and if so where? Or was a lucky junkyard find? Looks great. I've considered this on my ST1 but I don't want to lose my hard buttons. I'm such a 90's gen-xer LOL.
Reactions: StanE
Discussion Starter #6
Check out www.naviupgrade.com for lots of great information and guidance on this. In my case I got the key parts out of a 2018 Focus SEL and the rest from naviupgrade.com and/or his recommended links.
Discussion Starter #8
Can I ask what this set you back dollar wise?
Sent from my SM-G975U using Tapatalk
Of course! Here are the major items and what I paid for them:
Custom Wiring Harness and As-Built Software Flash Files: $250.00 (www.naviupgrade.com)
USB Hub Adapter: $20.00 (www.naviupgrade.com)
Satellite Radio Antenna: $15.79 (Amazon)
GPS Antenna: $9.99 (Amazon)
Sync3 Compatible USB Hub $80.00 (Amazon)
USB Cable: $7.99 (Amazon)
Secondary USB Input Port and Cable Adapter (Optional): $17.00 (Amazon)
Excellent Used Pre-Facelift Focus ST Sony Controller/Touchscreen Bezel/Vent Panel: $120.00 (eBay)
Excellent Used Complete SYNC3 APIM with Nav, Screen, Sony ACM with Satellite Radio, HD Radio, plus the correct brackets to fit Focus: $599.99* (eBay) - from a 2018 Focus SEL
* Also included a Facelift Focus Sony Controller/Touchscreen Bezel/Vent Panel from the same car which I will resell - credit $25.00
Grand Total: $1,095 plus my labor - more than I expected actually, but I couldn't be happier with the result. :sneaky: - it feels like stepping into a new car again.
In the grand scheme of things, this is right on par with aftermarket double-DIN units with car play/android auto/NAV, install kit etc.
Discussion Starter #10
Given the choice I do prefer to keep my upgrades looking "plausibly stock" ;)
Discussion Starter #12 (Edited)
Some more details about where I got the hardware and what I paid is below, or somewhere on this thread...... ;) .
I agree. I was just commenting, that you didn't spend a lot.
I have a Sync2 car, I upgraded to a Sync3 unit, and use a RF DSr1 to integrate my amps and such. It's awesome. I admit the DSR1 is not without its faults in terms of BT connectivity, and my JL Audio Stealth Sub can't get all that loud. But overall, I've got a vastly upgraded system from stock.
Discussion Starter #14
I seriously considered the JL Audio Stealthbox too. I hear it goes a lot lower than the OEM Sony sub, looks stock (ish) and obviously would work well with the rest of my JL audio gear, but I just decided to go for the totally stock look and do the best I could with the Sony sub by stuffing it and upgrading the woofer unit. Overall it is really clean, tight and loud and deep enough for me - I'm not trying to vibrate the car apart and/or win any sound-offs :p
Do you have part numbers for the stuff ordered ? I have access to a part out sync 3. Does the custom harness you use come with a canbus flash for the vin change? I’d appreciate your help , as I’ve found a kit but it’s in the $2800 range and I know there’s gotta be a cheaper way
Discussion Starter #17
I’d planned on doing this and running this so I can wiring up Amps
Yeah - as far as adding better sound/amplification downstream goes, this should get the job done too.
Discussion Starter #18 (Edited)
Sorry, I don't have actual part numbers, other than knowing that my SYNC3 APIM, SCREEN and ACM all came from (the same) 2018 Focus SEL. Being a 2018, it was a later version of SYNC3 - it is best to avoid the very early SYNC3 APIMs that came in 2016 cars.
If you buy the adapter harness from Brian Lovelace (www.naviupgrade.com) - cost $250.00 - he will also supply as-built files for the APIM and ACM that will be good enough to get you going. There is also a wealth of information on that site about how to go about the upgrade and which SYNC3 APIMs to look for etc.
If you buy the adapter harness from Brian Lovelace (www.naviupgrade.com) - cost $250.00 - he will also supply as-built files for the APIM and ACM that will be good enough to get you going. These is also a wealth of information on that site about how to go about the upgrade and which SYNC3 APIMs to look for etc.
Did his harness and files set you up with a 1
Zone climate control on the sync screen?
Discussion Starter #20
No - and not needed anyway in my case - the ST1 has manual climate control anyway, so there is nothing to "control" .....?
1 - 20 of 21 Posts
