1 - 2 of 2 Posts
I've narrowed it down to these two for my '14 that has 71k on the original struts. I thought the stock setup was quite good, before it got worn out, but loose at high speeds. I don't really want it lower, but as long as it's not slammed it's fine, my priority is handling and a well matched, well controlled setup.
The b14 has rates in the 300's, whereas the mountunes are in the low 200's. The b14 is stiffer, but lower. I'm not sure which is the better matched spring to the b8's, or which setup is better matched to the car.
Thoughts?
Discussion Starter #2
Or b8/swift? Lol, I guess my point is a b8 is a b8, only one of those 3 springs will match best, given the different spring rates.
1 - 2 of 2 Posts
