1 - 3 of 3 Posts
Hi there.
Been having the rear end getting really upset over minor imperfections in the road. If you've ever driven a solid rear axle truck you might know the feeling of the the rear end squirming around underneath the car.
I've looked underneath, nothing super obvious. Is it normal to be able to wiggle the rear control arm a little bit? Or should it be rock solid?
I'm going to try removing the rear sway bar tio, see if that helps any.
how many miles? sounds like you may have a bad sway bar end link or worn out bushings or possibly shocks/struts.
Thanks. It's got 55,000 miles but only about 30k on the B8 shocks and Massive end links.
I suspect a bushing, curious if any are known for going this early.
1 - 3 of 3 Posts
