1 - 16 of 16 Posts
ok, I just wanted to make sure it wasn't a feature you were looking for in the cluster's options/settings.
that would make sense, most of the time when there is a connection issue, it is usually a problem with the OBD adapter. was it connecting before and then now its not?
connect to forscan, check speed
disconnect and close forscan
connect with focccus app
read bcm, change things
write to bcm
done
I had an error writing the first time, I jsut hit it again and it ran fine the second time
I can get my elm 327 to connect but not my obdlink.
write to bcm
done
You can give this a shot but I have try it on 2 2017s and no luck. I had to use ForScan to program the windows. I have also programmed 4 RSs as well using the same method in ForScan
DIY: Global Windows Open/Close
[/QUOTE]No grief on the warranty because they did it. And it cost me nothing because it was part of my complimentary 1st [/QUOTE]
Took mine to the dealer they wanted $127 to "look into it" as they weren't sure it could have been done. Found a local guy that did it for way less lol
I did mine today along with enabling the “ST Performance” boot screen. Just followed the instructions on DIY: Global Windows Open/Close
hello, how did you do it? with FOCCCUS? and ELM? what year is your Focus?
i had 2013 and 2016 STs . and the cable ELM and Focccus Worked just fine , but now that i have the 2017 there is an error when i try to connect.
1 - 16 of 16 Posts
