Anyone running the Garrett G30-770?
530 😳 he’s spinning through 4th lolI've not heard of that one being run yet but Alan just told me he just tuned a g30-660 that made 530whp at 30psi using an ATP kit. Not sure what engine mods were.
Yeah I jumped into it in third at 3k the other day. At 4K it let a loud and long tire screech. That’s with a G25-550 and a 4 port auxiliary fuel running e85. Maybe 450whp and it peaked at 28.85 psi.530 😳 he’s spinning through 4th lol
LSD with sticky tires totally changes that and puts the power down.Yeah I jumped into it in third at 3k the other day. At 4K it let a loud and long tire screech. That’s with a G25-550 and a 4 port auxiliary fuel running e85. Maybe 450whp and it peaked at 28.85 psi.
I’m in the process of trying to install the atp kit I had to cut the axle carrier bracket and stud waiting on sanding disc to come in to sand down the compressor housingAnyone running the Garrett G30-770?
does it hit the block?I’m in the process of trying to install the atp kit I had to cut the axle carrier bracket and stud waiting on sanding disc to come in to sand down the compressor housing
That bracket and stud are pretty important...I’m in the process of trying to install the atp kit I had to cut the axle carrier bracket and stud waiting on sanding disc to come in to sand down the compressor housing
No it doesn’t hit the blockdoes it hit the block?
I see the issue, I'm surprised its sitting so low, that seems incorrect.No it doesn’t hit the block
Haha, wow thats a huge difference! Surprised it fits still. I know some people have mounted larger turbos where the battery normally sits. While i like being able to see a turbo, i dont like how they usually hood dump the exhaust.
