Curious about the weapons R anti fouler. Is it just a plug and play? Does one side screw into the dp and the plug goes into the other side? What about the J style oxygen restrictor, what is the difference?
Awsome thank youThey both work the same way, just different shapes. Once is a L, one is a more curved piece. Screw one end into the downpipe, then screw the o2 sensor into it. It removes the o2 sensor from the exhaust stream so it will see lower levels of pollutants and in turn trick the car into thinking a catalytic converter is removing them.
Which one is dormansAll I can say is the Dormans will not work without modification due to the length of our CMS sensor body.
Which insert would u recomend using. I have the mbrp catless dp.Vibrant 11620 will do the trick
AFAIK it dont have inserts, thats another "model"Which insert would u recomend using. I have the mbrp catless dp.
