Hello!
I was able to get a lot of inspiration and direction on how to go about installing a WMI kit from this forum. So I wanted to document the approach I used to install the WMI kit. Hopefully it will help someone else out!
I decided to go with the Snow Performance Stage 1 kit. My goal is to suppress knock, help reduce intake valve buildup, and lower intake charge temperature. I am not after a huge HP increase, but I will report back if there is any improvement in acceleration.
I thought about installing the WMI tank in the trunk, but I use this car a lot, and that would limit the utilitarian functionality of this car. So I will be using the windshield washer reservoir as the WMI tank.
Progress so far, I have made a bracket to hold the pump:
It's just some 1/4" flat plate welded into a rectangle shape. The support rods are actually some old Air Cooled VW cylinder studs I had left over from an engine rebuild. The washers are also from the ACVW Cylinder heads. They should be strong enough to support a WMI pump. Next I added some support rods (which are actually ACVW pushrods), some 1/4-20 threaded rod, and painted it:
After that I mounted the pump to the bracket and crimped on a weather pack terminal to the pump:
And finally I mounted it to the car:
That's all for now! Next I will drill the reservoir and add the self-sealing tank tap. Then plumbing and Damond Throttle body spacers, and finally...the wiring. Also I am kinda happy that some old VW Beetle parts made it on to a 2016 Focus
A small piece of my Bug lives on in a new platform.
