1 - 4 of 4 Posts
I live in Las Vegas, temp was around 111F today and I could only pull boost to halfway on the gauge. This is going WOT... is this normal?
If you are completely stock then yeah heat soak is gonna rob you of power pretty quickly. Even if you are heavily modded it's not a great idea to push your car hard in those kind of ambient temperatures.
If you have a Cobb AP, be sure to check if your in valet mode (accessed via the cruise control)
This! Also if you are thinking heat soak take a look at your Charge Air Temps.
1 - 4 of 4 Posts
