I didn't realize there were so many DIY intercooler threads. But I already typed this up so I decided to post it. Mine is a tiny bit different in how it mounts. Take it or leave it.
Note: there are fantastic pre made kits offered by all of the vendors. They are hassle free and will perform well every time. The vendors are what makes the ST community a symbiotic place and they all sell excellent products. Consider that route if you are not willing to cut metal and drill holes. This DIY tutorial will save you money but may cost you install time.
Parts list total $321:
Intercooler core:
Amazon.com: ETL Performance Front Mount Intercooler Bar and Plate 30.00"W X 9.00" H X 3.23" T X 2.50" ID: Automotive&
(1) order of 2 support straps - 1/4" thick by 1-1/2" wide by 15" long (6061 aluminum shown, but you can make it out of whatever you have handy)
Amazon.com: 2 Pieces 1/4" X 1-1/2" ALUMINUM 6061 FLAT BAR 24" long T6511 New Mill Stock .250: Home Audio & Theater
ATP charge air sensor elbow:
edgeautosport.com
(2) 90° elbows with T-bolt clamps
https://www.amazon.com/gp/product/B07VRWXFDP/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
(2) 2.5" OD pipe couplers to clamp to
https://www.amazon.com/Universal-Connector-Stainless-Khaos-Motorsports/dp/B07N96VDP3/ref=sr_1_3?dchild=1&keywords=2.5"+ID+to+2.5"+ID+Universal+Exhaust+Pipe+to+Pipe+Coupling&qid=1610474377&s=automotive&sr=1-3
(1) set of mounting hardware hardware ( you can also use whatever hardware you have handy. the holes in the core are 3/8" and the bolts need to be at least 4")
https://www.amazon.com/16-18x4-Stainless-Screws-Washers-Diameter/dp/B08DTF6VF1/ref=sr_1_19?dchild=1&keywords=5/16-18+4"+bolt&qid=1610480604&sr=8-19
i've found quite a few build guides on here so I'm not going to write one.
Here's a great one:
www.focusst.org
Also here's a good youtube video:
I do my couplers exactly like his except make sure that you rough up the 2.5" pipe couplers. if they are smooth they will blow off.
I simply did this with a metal file to make the surface that gets clamped on have some grip.
A difference of my build is that it mounts the intercooler so that there is about 4 inches of space between the radiator and the intercooler. This helps the intercooler cool very effectively as it can cool from both sides instead of being sandwiched against the radiator.
You will need a high speed cut off wheel to grind the straps to length. I cut mine to about 15"
You will also need a couple of 3/8" drill bits to go through the bash bar.
Line up your holes twice before you drill them. They take forever to put through the bash bar. The aluminum straps are easy.
I couldn't find a good picture of how I did the straps but here's a sketch. Straps are in red. they go on the back of the intercooler.
Again, measure twice, drill once.
I like this design because it makes the intercooler very prominent in the grill. It will however prevent you from using Active Grill Shutters ever again. Which the AGS actually really help with drag and gas mileage if that's your thing.
I did this mod several months ago and its been running fantastically. Cools very well.
Intercooler core:
ATP Turbo Sensor Mounted Intercooler Elbow Ford Focus ST 2013-2018
When you replace your stock FMIC unit with a core that doesn't have a built in MAP sensor flange on the Focus ST, the ATP Turbo flanged elbow works perfect.
Here's a great one:
GReddy DIY Intercooler Install
This project has been In the making for about 2 months now. First off I want to say thanks to Silver_shooter, Kevin, and most of all ST3 4 ME! Help from them was necessary for me to get this install done, as It is was my first time doing one. Overall The install went really smooth, and only took...
